View ACE Port Statistics
Use port statistics to ensure that the ACE is operating correctly.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select a field on the ACL tab.
- Select ACE.
- Select the Statistics tab.
Statistics Field Descriptions
Use the data in the following table to use the Statistics tab.
Name |
Description |
AclId |
Specifies the associated ACL index. |
AceId |
Specifies the ACE index. |
MatchCountPkts |
Specifies a packet count of the matching packets. |
MatchCountOctets |
Specifies the number of octets of the matching packets. |
GreenBytes |
Specifies the number of bytes sent with a rate lower than the committed-rate of the matching ACE. |
GreenPackets |
Specifies the number of packets sent with a rate lower than the committed-rate of the matching ACE. |
YellowBytes |
Specifies the number of bytes sent with a rate lower than peak-rate and higher than the committed-rate of the matching ACE. |
YellowPackets |
Specifies the number of packets sent with a rate lower than the peak-rate and higher than the committed-rate of the matching ACE. |
RedBytes |
Specifies the number of bytes sent with a rate higher than the peak-rate of the matching ACE. |
RedPackets |
Specifies the number of packets sent with a rate higher than the peak-rate of the matching ACE. |
